Resets MPLS configuration parameters to the default settings. This command does not delete the VLAN from MPLS.
vlan_name | Specifies the VLANs for which MPLS is unconfigured. |
N/A.
This command resets all MPLS configuration parameters for the specified VLAN to their default values. It does not delete the VLAN from MPLS. These parameters include the enable state for LDP and RSVP-TE, the bandwidth reserved for RSVP-TE LSPs, RSVP-TE timers, and the RSVP-TE metric. MPLS does not have to be disabled to unconfigure a specific VLAN.
The following command resets MPLS configuration parameters to the default settings for a single VLAN:
unconfigure mpls vlan boone
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
